Re: 706 D282 Cracked Head.....
Posted by The tractor vet on December 28, 2013 at 16:46:47 from (75.19.125.103):
In Reply to: 706 D282 Cracked Head..... posted by LD in PEI on December 28, 2013 at 13:34:58:
You can try and flush the block and cooling system and get all the antifreeze cleaned out then get her good and warmed up with plain old water and dump a can of K & R block and head sealer in it and run it hot for i think about and hour maybe less then shut it off and drain the WHOLE system . Do not allow that stuff to get on the paint anyplace . Then ya let her set for 24 hours with all the drains open including the block drain . This may solve your problem .
