Valve Adjust by Jim --- It is simple and fool proof. The process works for all engines with adjustable poppet valves and any number of cylinders. Identifying the valve order is all that is necessary (given in this process for the IH 4 cyl gas). Setting .020 cold is good. I do it this way others do a different system. It must be set cold first, so setting it twice (or once) is normal Get the specification. Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open. Set the exhaust when the intake just closes. These are the two positions that can be seen at the springs and retainers for each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is. The order is (front to back EI-IE-EI-IE) Look at #1 valves, Turn the engine till the Exhaust just starts to begin opening (moves) then adjust the Intake valve. Rotate more until the intake just stops moving after having been o
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
