Re: Belt Pully Attachment
Posted by rustred on December 29, 2013 at 10:15:18 from (74.214.152.80):
In Reply to: Re: Belt Pully Attachment posted by Dave8N in Pa on December 29, 2013 at 09:24:15:
well if the trans is locked then you are stuck in 2 gears at once. remove the gear shifter and re- align the shift rails with a cat bar. this is the simple fix, but your shifter end will need building up to cure the problem.
