Re: Super C gas valve/filter
Posted by gene bender on January 01, 2014 at 14:47:45 from (207.177.56.213):
In Reply to: Super C gas valve/filter posted by mountain4don on January 01, 2014 at 13:46:27:
Thats your problem getting one at Orscheln the rubber gasket is the wrong size screen goes on the sediment bowl then rubber gasket get the correct size and you will be good to go. Take your glass bowl to an auto parts store and get the correct size. Mite even have the wrong size screen it is smaller than the rubber gasket. Check your metal base on the sediment assy to make sure it isnt sprung as lots of pliers were used to tighten the bowl and in the process sprung the metal where the gasket seals.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
