Super C gas valve/filter
Posted by mountain4don on January 01, 2014 at 13:46:27 from (71.1.123.92):
My original gas valve/filter on my 1954 gas fired Super C Farmall was pretty corroded and the filter screen rusted out of it, so I decided to replace it with one I bought from Orscheln. The new one went in ok, but when I turned the valve on with gas in the tank it leaks around the glass bowl. The rubber gasket inside just seems to want to slide into the center inside of the glass bowl and leak. And I don't see how this rubber seal trapped between the glass bowl and the filter screen pushed against the metal body is supposed to seal anyway. I would think that the gas will just leak horizontally through the screen to the outside. What is the solution to this problem? Or are these gas valve/filters just no good?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
