Re: H Cam Gear
Posted by Bob M on December 13, 2000 at 08:39:31 from (192.232.119.194):
In Reply to: H Cam Gear posted by Jim on December 13, 2000 at 04:06:38:
Jim - I recently replaced a busted cam gear on a Super M. Here's how I did it: 1 - Purchased a replacement gear (I got a new one from Carter & Grunenwald). Once I had the new gear in hand.... 2 - Jacked up the tractor and supported it from the clutch housing, leaving front wheels a couple inches off the floor. Drained the cooling system and removed the radiator hoses. 3 - Unbolted the upper bolster from the frame rails, then loosened the motor mount bolts thru the frame rails. Disconnected the steering shaft at the U-joint. Removed the entire front bolster, wheels and radiator as an assembly (you'll need an engine hoist or a front loader for this step - the bolster assembly is VERY HEAVY!) 4 - Removed the crank pulley nut (needs a 1-1/2" socket for the Super M - your H is probably a size or two smaller). Once the nut was removed the crank pulley slid easily off the shaft - no puller required. 5 - Removed about 15 or so cap screws holding the timing gear cover on. Not all the cap screws come in from the front - there's one or two that come in from behind the governor, a couple come in from the distributor side, and two that come up from the bottom thru the oil pan flange. Also keep track of where each screw comes from - there's 3 different lengths of screws used. Carefully remove the gear cover. Beware - it's cast iron and heavier than it looks! 6 - Turned the crank until all of the timing marks (1 on the crank gear, 2 on the cam gear, and 1 on the distributor drive gear) are in register. 7 - Removed the keeper, then the cam gear nut (1-1/4"(?) nut). Note - the nut is LEFT handed on the Super M; believe however it's right handed on the older tractors. If the shaft turns when you try to loosen the nut, jam a shop rag into one of the timing gear meshes to prevent it from turning. 8 - Finally pull the old gear off the camshaft. Be careful to not lose the Woodruff key from cam gear - it's an odd size and not readily available except from the dealer or a boneyard. Reassembly is essentially the reverse of the above. I did not bother with a new gasket for the gear cover - simply scraped old gasket from the mating surfaces then coated them with a light bead of Permatex red silicone gasket maker just before assembly. Also... You're gonna need a couple of big sockets to get the crank and timing gear nuts off and back on. If you don't have a 3/4" drive socket set, suggest borrowing one for a few days. Link below has several photos of various steps of the replacement process. Hope this helps and good luck!! Bob M
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
