Re: Off subject but......
Posted by Dennis Frisk on December 13, 2000 at 10:40:07 from (12.4.181.2):
In Reply to: Off subject but...... posted by RB on December 12, 2000 at 18:49:01:
CRC makes a spray-on red elec. connection protectant that actually works better than grease. Spray several coats on, it's thin to soak into small spaces, Use the heat shrink tape with it and maybe look for the felt washers to go under the post connectors & side mount terminals and you should eliminate your problems. If you have alum cables, definetly use copper, welding cable would be good.
Post A Followup
: Re: Re: Off subject but......
