Who knows? I usually avoid commenting on 12-volt conversion problems because you never know what creative approach somebody did.
I noticed the 2 red wires on the same end of the resistor and initially thought the same as rusted nuts. But I then noticed there is also a black wire on the other end of the resistor. What, if anything, the resistor is doing depends on what the other end of each wire is connected to.
The red wire matches the added wire from the resistor to the coil. Therefore I assume it was added as part of the conversion and goes to the obvious place. If the greasy black wire goes to the ignition switch, the resistor is wired properly to drop voltage to the coil. To know if it is wired wrong, the first thing you should do is find the other end of the red wire. The prior responses assume it goes to the ignition switch.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
