Posted by rankrank1 on January 03, 2014 at 12:46:22 from (166.137.101.170):
In Reply to: m farmall alternater posted by ohiojim on January 03, 2014 at 10:08:55:
Use the Hitachi. It wires up basically the same as the Delco 10SI and is quite a bit smaller in size so fits under the sheet metal much much better. About $45 to $50 or so from Advance, O'Reilys, Autozone with lifetime warranty.
Search the archives and it will tell you the vehicle to look up to obtain it. I think it was a 1980's Dodge D50 pickup which was a foreign built truck imported for Dodge.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
