The Hitachi is seriously easier to fit. The Use of 1/4" female insulated spade terminals works on the connections. The S terminal connects directly to the big terminal with a short wire, 14 gauge is OK. the L terminal connects to the ignition through a marker lamp (not LED style)or a 10 ohm 5 watt resistor, or a diode with the band toward the alternator. It should get power from the ignition switch, full bat voltage. The big terminal attaches to the amp meter using 10 gauge wire. (reverse the leads on the amp meter, hook the battery up negative ground, and replace the light bulbs.) I like to put a 40 amp fuse, or fuse link, in the wire going to the Battery from the amp gauge to protect things if connections are made wrong when jumping, or the alt fails. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
