Re: Wiring on a Farmall 140 12v Conversion
Posted by Janicholson on January 04, 2014 at 09:22:19 from (69.146.159.98):
In Reply to: Wiring on a Farmall 140 12v Conversion posted by RTR on January 04, 2014 at 08:56:56:
Th Alternator that is on it is probably internally remade to be a "one Wire" install. The idea is that if the regulator is made to sense voltage internally all the time (never shuts off) it can start and operate with only the single output wire connected. It does work, but has two issues. one is that the continuous drain of being "on" can and does drain the battery when the unit is not operated for a period ranging from 5 days to a month (some conversions are better than others). The second issue is that they often require higher rotation speed to begin charging. Sometimes needing full throttle to begin charging.
The consensus is that it is a OK method, but oly if the above issues are not a problem.
I recommend that same alternator, or a Hitachi 14231 from a 86 Nissan D21 PU.
They are wired as a three wire installation.
The main output wire, a sensor wire S on the Hitachi, and #2 in a Delco 10SI) and a idiot light circuit. with a source of voltage coming from the ignition switch and having a resistor, or a bulb, or a diode in it to prevent the tractor from running when the switch is shut off. This source is 12gauge, and is hooked to the L terminal on the Hitachi, or #1 on the Delco. Note that the use of the ballast resistor for the coil is required if the coil is original 6v, or labeled with "for use with an external resistor" on the can of the coil. If this solves your issue let us know, or ask more questions. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
