Farmall H Governor Spring Length
Posted by Oregon Tractor Jack on January 10, 2014 at 18:49:19 from (50.137.47.135):
Has anyone else had problems with the length of the after market governor springs? I was having trouble with the throttle on one of my H's. It would idle fine, but when I pulled on the throttle lever it would travel about half way through its movement before the engine speed would increase. I adjusted the governor as per the IH manual, but it still wasn't right. I finally pulled the spring from another H that was working correctly and swapped them. The throttle problem went away. I found there was a difference of about an 1/8" in the lengths of the springs. The longer spring I just purchased online. Seems to me there could be alot of "OEM" parts out there that are not in "SPEC". I have ordered a governor spring from Case/IH to see if it is any better.
Anyone else have this problem?
Thanks
Oregon Tractor Jack
