dt414 to 466 swap / 856 power steering
Posted by E Conrad on January 11, 2014 at 20:30:59 from (207.7.74.177):
I have a 1066 with a bad dt414 and considering a dt466 swap. Will a dt466 out of a school bus be compatable or need any special modifications??
Also, I have a 856 that the power steering works effortlessly at idle, but as rpm increases it gets to where it is almost impossible to turn the steering wheel. Any clues on this would be helpful..
Thanks
