Re: Farmal 450 Diesel starting problems
Posted by brian on December 14, 2000 at 13:18:55 from (205.188.195.48):
In Reply to: Farmal 450 Diesel starting problems posted by Eric Lagemann on December 14, 2000 at 10:40:25:
When running on gas, they need the same things that any other gas engine needs -- gas and spark. Ether it and see if that helps to isolate carb problems, and then check ignition, points, etc. Also these engines don't want to see more than about .025 gap on the spark plugs. I usually set mine to .020 and it starts right off .
Post A Followup
: Re: Re: Farmal 450 Diesel starting problems
