Inner axle bearing--Jim and guys
Posted by Lynn Kaufmann on January 13, 2014 at 19:28:28 from (76.84.125.101):
I did some pricing on the 300 inner axle bearing. The IH dealer said it was $125.00 and did not know the number of bearings in it. Another place had one for 102.00 but only had 10 balls. I ordered one from Motion Industries as everyone recommended and it was $126.00 with 15 balls in it. It is also a covered bearing so I have to pry off the outside covers. When I took mine out it had 16 (I hope because I have no other damage) and since the inner cage retainer was totally gone except for a small piece over 2 balls I found in the big differential drain plug. Thoughts on this????
