Headlight switch wiring
Posted by sony224422 on January 15, 2014 at 07:15:51 from (12.111.44.98):
I have a converted h with 12 volt with electronic ignition and was working on wiring the head light switch. From what I've gathered, the two terminals that are tied together with the spring resistor are for the regulator which I don't need because I have my alternator excite wire on my ignition switch. But every diagram shows a square switch where as I have a circle switch. I am not even sure if the feed for the switch is correct as it was done by the pervious owner. I also have the switch on the right head light as well. Is that to have seperate head lights or for adding a tail light?
third party image
third party image
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
