H Countershaft Oil Seal Question
Posted by Reinders on January 15, 2014 at 08:03:30 from (216.56.48.99):
I am putting back together an H and once I put the transmission fluid in the oil seal on the countershaft nut is bad. I need to replace it, but I am not sure how to remove it. The shaft connecting the hydraulic is removed and the bearing retainer is loose, but I don't want to ruin anything. Does the nut and retainer pry loose or is it threaded. So I need to get back into the transmission to remove the seal? I've attached a picture so you know what I am talking about. Any help is appreciated. Thanks.
