That coupling is screwed onto the front of the countershaft with standard, right hand threads.
Removal is straight forward: Lock the countershaft from turning by engaging the PTO then holding the PTO shaft with a large pipe wrench. Or remove the shift lever and use a large screwdriver to engage 2 gears at once (reverse and 2nd are my favorites!)
Now grab the coupling nut with another large pipe wrench and tug HARD. Or put a piece of keystock into the slot to act as a lever and give it a good lick with a hammer. Once started the nut will spin off the rest of the way easily by hand.
Suggestion: While you're in there, replace the upper (input shaft) seal too. Good chance it also is worn out.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
