Re: Broken bolt extractor in engine block
Posted by rumplestiltskin on January 18, 2014 at 08:31:32 from (108.239.55.33):
In Reply to: Re: Broken bolt extractor in engine block posted by Tom Fleming on January 18, 2014 at 06:20:04:
Your experience and advice are the same as mine, Tom. The only method I use anymore is a succession of larger and larger left-handed drill bits. I've had 100 percent success with that, and very little to no thread damage.
Mark W. in MI
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
