Re: Broken bolt extractor in engine block
Posted by 2pipe on January 18, 2014 at 19:07:03 from (198.45.167.21):
In Reply to: Re: Broken bolt extractor in engine block posted by Tom Fleming on January 18, 2014 at 06:20:04:
I am with you guys on the idea of avoiding easyouts at all cost. I have removed a lot of bolts that were broken off flush or slightly down into the hole by drilling a small hole through the bolt then welding a nut on, spray some penetrant or hyd oil on it, and walk away from it until it cools completely. As it cools it will pull the oil down into the threads, and by first drilling a hole in it the weld will penetrate better without
