Re: Broken bolt extractor in engine block
Posted by Lynn Kaufmann on January 18, 2014 at 20:24:33 from (76.84.120.214):
In Reply to: Re: Broken bolt extractor in engine block posted by Tom Fleming on January 18, 2014 at 06:20:04:
I have had a lot of success if first you drill a SMALL hole in the CENTER of the bolt. Then use some heat on the bolt and area. Next spray Deep Creep into the hole and let it cool. If you read Deep Creek's instructions, they recommend the heat, plus it is much cheaper than Kroll's and I think works way better. After it cools, drill with the correct size drill for the easy out ALL the way through the bolt. This I have found seems to let the bolt shrink to a smaller diameter. Then use the easy out with a gentle rocking action. Like a very slow impact wrench. Now it it does not come out (which it has for me most of the time) you now can finish drilling out the bolt to the correct tap size and tap new threads.
