Re: F20 road gear identify?
Posted by 38F-20 on January 18, 2014 at 20:46:28 from (71.34.185.194):
In Reply to: F20 road gear identify? posted by mschwartz on January 18, 2014 at 19:36:34:
I could be wrong but I think that is a Bennett road gear. It's a little different than the traditional Behlen as the lever to engage is out the top instead of the side. The speed of the tractor with 28" tires will be determined by the gear ratio of the box, tire size, and the rpm of the motor. My F-20 has a 2.25 ratio with 13.6x36 tires and I know it is turning over on rpm. I clocked it with a gps at 17 mph. Maybe 10-12 mph?
This post was edited by 38F-20 at 20:48:50 01/18/14.
