Re: 1486 Draft control lever won't move.Need info
Posted by mazemeister on January 19, 2014 at 09:23:44 from (69.127.90.15):
In Reply to: 1486 Draft control lever won't move.Need info posted by Larry B. 1486 on January 19, 2014 at 08:52:20:
both the position control and draft control levers have a friction adjustment i think it's 7/16" or 1/2" wrench to turn the bolt. if you stand behind the tractor and look up between the cab and right rear wheel, you'll see the 2 linkage rods running fore/aft next to each other.
if it's seized up inside, not sure what you'd do about that.
