Re: Farmall H Magneto Timing
Posted by Zachary Hoyt on January 20, 2014 at 08:55:34 from (74.47.51.121):
In Reply to: Re: Farmall H Magneto Timing posted by Reinders on January 20, 2014 at 08:51:49:
I can't advise about removing the cover or not, but I am guessing that the mark would be on the back side of the gear so it could be seen when bolting up the mag drive. The governor is not timed as far as I know, it is not doing anything that requires timing as I understand it.
Zach
