Update on H
Posted by Dave8N in Pa on January 20, 2014 at 11:11:39 from (72.9.24.169):
Ok gents, I found the problem. I think. The part that acts like a U-joint is broken. Not sure what the right name is. Not sure where to buy one either. Not sure if they still make new ones. Not sure I want to settle for a used one. Not sure why it is broken. Not sure if it is all that needs replaced. Not sure if I can replace it without dropping the pump. Advice will be vary welcomed.
