SMTA clutch job
Posted by DK44H on January 20, 2014 at 17:05:29 from (96.31.177.224):
Hey guys, just replaced the clutch disk and pressure plate on my SMTA. Had the flywheel resurfaced as well. I"ve replaced the appropriate seals and bearings while in there. Only question I have is how difficult is it to replace the seals in the transmission input shaft carrier? I have the I T manual and it says to remove the three bolts holding the bearing cage and pull it out. Is it really that easy? I"ve never done one. It doesn"t appear to be leaking but if I"m already apart shouldn"t I replace it anyway? Hope this makes sense. Sometimes things that make sense in my head don"t always type out the same way!
