mcv
Posted by gbs on January 21, 2014 at 14:46:52 from (68.115.212.154):
our 1086 is a ta delete but still has the mcv with ta controls, what changes were made to allow it to work without the ta,in the near future I want to reinstall the ta,another question is I need to test the mcv pump and the style mcv valve we have has to tap into at the lower right hand plug,manual says to remove orifice behind plug to test,it shows a special removal tool to remove it,can any other tool be used,is it thread in or what
  • Re: mcv gbs 16:10:12 01/21/14 (0)
  • Re: mcv Owen Aaland 15:14:11 01/21/14 (0)
