Re: fast-hitch filler plate picture
Posted by gab on January 23, 2014 at 11:58:51 from (50.103.24.128):
In Reply to: fast-hitch filler plate picture posted by Al L. in Wisc. on January 23, 2014 at 11:00:42:
The set I got don't have the tee on the end but have the roll pin holes with broken pins, never needed them, not sure where I put them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
