Re: SMTA clutch question...again
Posted by Janicholson on January 23, 2014 at 14:54:29 from (74.60.94.18):
In Reply to: Re: SMTA clutch question...again posted by DK44H on January 23, 2014 at 14:09:57:
No. The clutch pedal needs to be where it belongs, If the return spring under the platform is broken, or weak it will not pull the pedal against the platform. If the pedal is not controlled enough to have that happen, the clutch pedal pivot must be fixed. A re-bush is pretty easy and inexpensive. Just have it made to the original shaft size and rebuild the shaft when it is warmer.
The clutch Pressure plate lever tips should not be adjusted!! The Vet and I basically gave the same adjustment info.
Jim
