Re: SMTA clutch question...again
Posted by DK44H on January 23, 2014 at 14:09:57 from (96.31.178.170):
In Reply to: Re: SMTA clutch question...again posted by The tractor vet on January 23, 2014 at 12:52:28:
I think I've found the problem. I think we are all talking about different things from what I can tell and that's probably my fault for not being clear enough. I do understand that the clutch pedal and the related linkages are well worn, my pedal actually is so worn that it returns on the outside of the deck. That's the next thing on the list to fix. I'm referring to the adjustment of the release arms on the pressure plate. It is to be 2 5/16 per the book. Currently when my clutch pedal is completely back against the operator deck there is no free play in the pedal because it appears that the TO bearing is still in contact with the release arms. Also, if I adjust the pedal so that there is 1 1/8 of space between the pedal and the operator deck the pedal does not come back all the way indicating that the TO bearing is already in the completely released position, or in other words, back as far as it can be. So when I'm under the tractor looking at the clutch and TO bearing, I'm seeing it all the way back, and touching the release arms at the same time. No matter what I do to the pedal or TA adjustments will change this.
My question is this, will I need to split the tractor again to adjust the release arms to properly obtain the small amount of space that should be between the TO bearing and the release arms when the clutch is engaged? If so, how much space is proper? I hope this helps. Sorry for any confusion.
