Re: SMTA clutch question...again
Posted by pete 23 on January 23, 2014 at 17:29:50 from (74.33.68.83):
In Reply to: SMTA clutch question...again posted by DK44H on January 23, 2014 at 10:21:07:
I see no one has asked where the fingers are laying. They should be very close to parallel with the pressure plate. It sounds to me like they are laying pointed toward the rear, the direction they normally move out to as the clutch disc wears. That means one of about three things. Flywheel step cut wrong, pressure plate been resurfaced too many times and out of specs(which I have had happen with HY-Capacity pressure plates) or the disc is wrong thickness. Splitting again would be the only way to do over correctly. A picture of it bolted to the flywheel would show all of us if it is right or wrong. If throwout bearing carrier is way back against the rear it has to be fingers way too far back or completely wrong bearing, carrier assembly.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
