SMTA clutch question...again
Posted by DK44H on January 23, 2014 at 10:21:07 from (96.31.177.224):
Hey guys. Got the new clutch disk and pressure plate from Hy Capacity with the 6 pad button disk put together yesterday. Did the throw out bearing also. Once slid together and bolted up tight I looked thru eh inspection hole on the bottom and noticed that the TO bearing is riding on the release leavers on the pressure plate. There should be a small gap between these right? I used the specs for that adjustment per the IT manual. I"m wondering if this clutch from Hy Cap has a different adjustment? If so I didn"t see any specs in the box. Can this be adjusted from underneath or will I have to pull it back apart to do it? Thanks for the help. DK
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
