hard to start
Posted by Roy Prins on January 24, 2014 at 17:18:41 from (96.31.24.201):
got a 544 with a c200 gas engine -- its hard to start -- it will only try to start with no throttle-- it fires on one cyl right away but wont keep going-- after about twenty trys it will go to two cyls. once runing on two it will go on three then four once warmed up it runs fine-- whats up with that? thank you in advance for any info -- Deacon Roy
