Re: Super A carrier bearing help needed!
Posted by Janicholson on January 26, 2014 at 17:12:54 from (74.60.94.18):
In Reply to: Super A carrier bearing help needed! posted by Warspite on January 26, 2014 at 16:39:48:
There is a pilot bearing in the center of the crankshaft. There is a throwout bearing that rides a tube shaft and pushes on the clutch release arms.
There are two styles of throwout bearings. One uses graphite and is just a solid chunk of carbon bonded into the mount. It does not turn, it just rubs directly on the fingers. They are OK just that way. The other style is a Ball bearing. it has a front race that touches the the fingers, and a set of balls then a rear race that is pressed into the mount. Jim
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
