Re: Torque tube problems
Posted by Phil Tibbetts on January 29, 2014 at 05:30:39 from (208.93.14.38):
In Reply to: Torque tube problems posted by chad from michigan on January 29, 2014 at 04:58:22:
Heli-coil should be stronger than the cast. Never had one pull out if installed properly.
