Torque tube problems
Posted by chad from michigan on January 29, 2014 at 04:58:22 from (70.39.176.177):
I have a Farmall 100 with fast hitch and loader. while using the fast hitch with a 4' fast hitch brush hog the bolts pulled out of the torque tube that hold the touch control hydraulic block to torque tube. Of course they will not thread back in. Question is pull it apart and try to add a heli-coil insert to the torque tube and hope it taps and threads the cast and holds or do I look for a new torque tube? What torque tubes will interchange? Will a super A thru 140 work or do I need something from the numbered series 100-140?
Thanks
