Loose seal on front end spindle
Posted by Jdetig1 on January 30, 2014 at 15:09:23 from (50.45.112.191):
I was packing the wheel bearings on my 1566 and I took the hub off and the seal kinda just fell off the spindle. The seal is supposed to press on to the spindle tight and the new one went on pretty loose. The other side was fine. I pinged up the spot where the seal sits and put locktite on it but the new seal still went on pretty loose. I would assume the seal will just sit there and roll around on the spindle. What should I do about this put some jb weld on it or weld a little on the spindle and grind it down or just leave it alone? Thanks
