Posted by Loren in MN on January 30, 2014 at 15:31:41 from (75.168.61.103):
A few months back, I mounted a second hyd valve under the seat of my 756 gaser, but didn't have the correct piping for the left hand(second) valve. Did have a second somewhat bent set of piping for the right valve when mounted as two valves and piping for a single valve, so I modified one set of tubing using the original single right piping from the front outlet, then changing the right rear tubing, then using the damaged right valve tubing for a two valve setup, modified it to fit the left valve and rear left outlet block. (If all that makes sense?) Someone asked to see pictures of the tubing. All works well, my son did the tig welding. Attached is also a pict of the correct piping in another tractor.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
