loose 450 gas sleeves
Posted by ep on January 31, 2014 at 09:52:33 from (70.209.129.84):
I am doing a stock rebuild on a 281 the new sleeves slip in the block.Is this common for this engine? I bore gauged the cylinders and they are round and straight.I always use the green lock tight on dry sleeves but they aren"t this loose in other engines.Some ford engines are designed this way but my 450 manual doesn"t mention this.
Thanks Eric
