Re: loose 450 gas sleeves
Posted by rustyfarmall on January 31, 2014 at 10:56:59 from (208.126.186.41):
In Reply to: loose 450 gas sleeves posted by ep on January 31, 2014 at 09:52:33:
If I remember right, some of those engines ended up with differing bores. Look for a letter stamped into the top of the block, right next to each cylinder. That letter will tell you if you need a slightly thicker sleeve, and how much thicker.
I do not know the codes.
