Re: Farmall 656 ignition problems
Posted by Janicholson on February 01, 2014 at 11:23:02 from (74.60.94.18):
In Reply to: Re: Farmall 656 ignition problems posted by Unforgiven on February 01, 2014 at 10:43:49:
I believe it is a resistor in the wire type. A plain wire (12gauge) run from the Key to the coil area, then to a 65 chevy six cylinder ballast resistor then to the coil, will fix it.
There is another wire going to the coil from the Starter solenoid. It is the bypass that is currently letting it start until the key is released. Jim
