Re: Farmall 656 ignition problems
Posted by Unforgiven on February 01, 2014 at 10:43:49 from (66.146.251.119):
In Reply to: Farmall 656 ignition problems posted by surveyor33 on February 01, 2014 at 10:36:32:
I think this model may have a resistor built into the power wire for the coil. You can hot wire the coil, if it keeps running it is certainly a resistor problem.
