Re: 53 Super H Stalling
Posted by Janicholson on February 02, 2014 at 07:12:26 from (74.60.94.18):
In Reply to: 53 Super H Stalling posted by chemrhetoric on February 02, 2014 at 07:07:26:
Yes you are doing things correctly. I suspect there are floating trash in the carb. But checking the ignition coil for excess high temp when it sputters is a good idea as well. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
