Re: Farmall M transmission stuck, will not move
Posted by FarmallM51 on February 03, 2014 at 16:33:46 from (173.20.33.193):
In Reply to: Re: Farmall M transmission stuck, will not move posted by Janicholson on February 03, 2014 at 15:26:24:
When I had the shifter out, I could see the 2-3 & 4-5 slides were lined up ok, but the R-1 was moved toward the rear and I couldn't budge it with a long screwdriver or the shifter when I re-inserted it, even with one wheel off the ground and the clutch depressed. If I take the bolts out of the belt pulley gear box, does it just lift off or is there anything tricky about removing it? If I take it out, and the R-1 fork is moved to the rear, is there a way to get a pry bar on it and move it forward?
