You will be able to see very well into the situation. First and reverse slider is the rearmose gear on the top shaft. moving it to clear the jamed situation should be easy with a flatbar or other small pry bar. However if the gera is actually loose, the shift rails may be the issue. there are detent balls and springs that can and do get out of their containment. If the 1/R sliding gear is loose on the shaft and will wiggle easily withing the confines of the shifter fork, the shifter fork is being held by the rails. Pulling the cover off then might be the only way to get at the problem. The 6 bolts that hold the pulley drive are easy to get loose. (the two highest bolts probably need to stay in the casting as they will hit the fuel tank, slide the housing up and out with those two in their holes but loose. Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
