Re: Farmall M clutch replacement
Posted by Redturbo on February 03, 2014 at 20:44:54 from (66.112.187.143):
In Reply to: Re: Farmall M clutch replacement posted by mkirsch on February 02, 2014 at 13:54:39:
The disc I took out is 12" & is fiber looking. The new disc from case IH 12" with 4 pads. But the center hub is smaller. Looked clutch disc, the disc I have is for IH clutch. 12" with 11 tooth hub, 1 13/64 of spline. The Rockford clutch is 12", 10 tooth hub, 1 1/2 of spline. Will have to see what local case IH partsman tells me tomorrow.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
