Re: Farmall M clutch replacement
Posted by D Slater on February 04, 2014 at 04:36:48 from (184.14.172.108):
In Reply to: Re: Farmall M clutch replacement posted by Redturbo on February 03, 2014 at 20:44:54:
You have a disc for a SMTA and some other IH tractors. All regular SM tractors before the use of a T/A used the same larger diameter splines. Most suppliers will probably be selling the same disc for a SM now for a Rockford or IH clutch. Probably doesn't have the original clutch in it anyway.
IH did sell # 359168R91 for that tractor then it was replaced by 362103R91.
Tell him to get a plate for a SM below tractor serial # 60001. Someone looked up a plate for above 60000.
This site shows some different types of discs for a SM in tractor parts.
This post was edited by D Slater at 09:27:21 02/04/14.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
