Re: Farmall M transmission stuck, will not move
Posted by FarmallM51 on February 04, 2014 at 06:49:32 from (173.20.33.193):
In Reply to: Re: Farmall M transmission stuck, will not move posted by glennster on February 03, 2014 at 14:47:06:
Took the belt pulley assembly off this morning and found the grease/water ratio in the transmission had exceeded the critical limit and frozen solid (well, at least semi-solid). I have 2 heat lamps on it now to thaw out. Still can't figure out why it would work on Saturday, but not on Monday. Guess enough creeped in from the last snowfall. Thanks for all the help
