Posted by mkirsch on February 05, 2014 at 05:41:27 from (65.199.189.6):
In Reply to: Governor on Super C posted by Schultz on February 04, 2014 at 10:41:21:
I've been down this road and it's no big deal to get the governor off and actually see what's wrong.
It's probably the thrust washer, but I recommend you replace the spring while you're in there because it's probably stretched and ready to break.
What gene was alluding to is "timing" the carburetor to the governor: With the tractor off, you set the throttle lever to FULL, then adjust the linkage between the governor and carb so that the pin will just slip through the clevis into the governor arm while you're pulling the carburetor rod all the way toward the front (carb butterfly fully open).
It helps to clean the holes in the clevis and the governor arm, and clean the rust off the pin so it slides easily when timing the governor to the carb.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
