Belly pum
Posted by Zeke5738 on February 05, 2014 at 17:12:21 from (64.21.231.207):
I recently hooked up a Saginaw 3 pt kit to my H. I plan to run my finish mower and my bush hog with this set up. I plumbed two lines . One from each side of the pump to the lower port on each lift cylinder. This worked for a while lifting my box blade but the three point is now stuck all the way up and my pump control lever will not return to the " impliment drop position". I do not have breather plugs on the upper cylinder ports. Any ideas? Thanks
